Mudita Kompakt: Wireless Qi charging doesn't work
The wireless charger may have to be lower output.
I have wireless charging success with a charger with specs:
Wireless Output 5V/1A, 9V/0.83A, 9V/1.12A, 9V/1.67A
The power supply I use to connect the wireless charger is low wattage.
I guess 5W to 7.5W or 10W may be the limitation for the phone if it is made to an older standard
The charger may “officially support slow charging”, the lower wattage, but the Kompakt OS is too dumb to inform the charger that it requires lower wattage.
Have you tried the wireless charger with a low wattage power supply, 5V/1A (5 watt) or 5V/2A (10W)?
Yes I am. I am positioning according to the open case photo showing where the battery is.
I can try but would prefer if someone could provide information of a charger that is confirmed working so I am not wasting money on buying a ton of chargers that don’t work! Do you have one that works for you and what is the brand?
I am sorry I cannot recommend a brand product, the specs from Mudita Kompakt are necessary for selection.
Finding a working wireless charger was trial and error, it’s an old wireless charger I purchased in 2020 and I have a low power usb power pack.
Qi wireless charging also doesn’t work on my Mudita Kompakt. I hear a half-second beep and vibration to indicate charging begins, then the beep stops and charging ends. I have a Slim Charging Pad with 17 W charger from Oakywood, which is compatible with all Qi devices with cases up to 4 mm thick.
Amazon.com: Wall Outlet Wireless Charger, Qi2 15W MagSafe-Compatible Magnetic Phone Charger with USB-C Port, Plug-in Cordless Design for Kitchen & Nightstand, Compatible with iPhone 17/16/15/14/13/12, Black : Cell Phones & Accessories this charger works with my kompakt
Dear @urszula Failure of common wireless charger compatibility. Is this an example of frustrating experience that a Kompakt owner experiences?
The lesson learned for improved customer satisfaction: Mudita Company Kompakt include a functional wireless charger with the new product.
Not my circus and not my monkey. :monkey:
@smuch Do you ever not have something to complain about? There is not a phone out there that includes a wireless charger out of the box. It would be nice if they could fix the compatibility issue / have a list of recommended compatible brands or even manufacture one that you could buy in the mudita store, but including one out of the box is just unrealistic.
A user named “smuch” is a highly active and regular contributor to the Mudita community. If you are looking for their specific thoughts, tips, or experiences regarding the minimalist phone, their posts cover several practical topics: [1, 2, 3]
  • Home Screen Shortcuts: They detailed how to quickly access the Alarm and Calendar just by tapping the time and date on the home screen. [1]
  • Stress Reduction: They shared that turning off the screen lock entirely (bypassing PINs and fingerprint sensors) made the phone much more relaxing and stress-free to use. [1]
  • App Inversion: They asked for (and found) instructions on how to invert the screen for certain sideloaded apps (like Spotify) that default to a glaring dark mode, which doesn’t display as well on an E-ink screen. [1]
  • App Management: They expressed that they keep their setup strictly basic, choosing to turn off features and minimize the number of apps to suit a calm lifestyle rather than relying on apps to track screen time. [1]
  • Prior Returns: Interestingly, they also chronicled their experience when the phone was first shipped, noting that they initially requested a refund before ultimately deciding to keep the device as a secondary tool. [1]
Can we verify that this Android core OS function exists in the MuditaOS K?
Why verify? Know what happens when I assume anything: ass-u-me
Troubleshooting, check all boxes
We are not alone, finding a charger that works is another expense.
Good idea, use the cable to charge, yes.
Our team I tested the wireless charging with a Baseus charger, with case fitted on no issues with charging.
It appears some wireless chargers work with the Kompakt and some do not - I don’t think the Kompakt has any wireless charging certification so chargers may need to be individually tested for compatibility. My belkin charger has the issue videoed in this thread, whereas a different charger I purchased does not.
UPDATE:
Good news: Various wireless chargers now work for my Kompakt phone!
That’s great! Glad you got it sorted out. Please share the brands that you tried, maybe that info will help other users.
suggestion Apple MagSafe Charger
@smuch Interesting :slight_smile: Thanks
