Is there a standard setting option to invert the Kompakt screen for specific apps that have a default dark screen, to make it light?
Reference: Spotify app theme is dark by default
Developer Options > Search “color”, it will open Text and Display Settings.
Tap on Color Inversion, first activate color Inversion Shortcut (this is a button that will float on the screen and allow you to toggle invert on/off).
@gezimos Thanks much - Where do I find “Developer Options”?
@ArmchairSetup please see above for how to set spotify screen light
