Clearing Recent Calls should be a button.
Yes, a Kompakt user needs to have Android development skills.
Iâm sorry, but I donât think weâre on the same page
I have absolutely no idea what youâre trying to do in the Notes App. Do you see a text-selection âSelect allâ command somewhere, despite Notes not having a dedicated Select All feature? Iâm confused.
I think the technically easiest fix is to do a factory reset but youâll lose your contacts and pictures. You could save all those prior to the reset. Once reset, other posts suggest the problem goes away. I know that since I cleared via abd, the problem has gone away. Not sure why it was a one time thing. Fingers crossed.
I decided to go for it. Iâve never used adb before now. I had chatGPT help me a bit on where to get the download, how to enable Debug over USB on my phone, all that jazz. Followed some of @jppelt comments (thank you) about how to issue the adb commands, although Iâm on windows and not fedora, so I donât think I can do the âgrepâ stuff.
Before upgrading, I wanted to get a baseline:
I connected my kompakt to laptop via USB cable, and ran this adb command from where I unzipped the adb sdk:
adb devices
That prompted my Mudita Kompakt to ask me for permission. I approved permission.
Before I applied the upgrade I ran this adb command to generate a report of my mudita call history:
adb shell content query --uri content://call_log/calls --projection _id:date:type:new:is_read
Then I ran it again to save that output to a file for later compare or review:
adb shell content query --uri content://call_log/calls --projection _id:date:type:new:is_read > calllog-1.5-before-upgrade.txt
Used chatgpt to give me a breakdown of the output and âtypeâ meanings:
| Call type | Count | Typical state |
Incoming (type=1) |
75 | new=1, mostly is_read=NULL count 75 |
Outgoing (type=2) |
153 | new=1, mostly is_read=NULL count 153 |
Missed (type=3) |
27 | new=0, is_read=1 count 27 |
Rejected (type=5) |
18 | new=1, is_read=1 count 18 |
Blocked (type=6) |
2 | new=1, is_read=NULL count 2 |
That above is my baseline.
Then I applied the 1.6.0 Update
It shows (9+) on my phone icon and wouldnât dissapear after going into phone app and viewing call history.
Then I ran this command to see generate a fresh post upgrade report:
Ran that again to save the output to a file for later compare or review
adb shell content query --uri content://call_log/calls --projection _id:date:type:new:is_read > calllog-1.6-after-upgrade.txt
The output showed that the calllog didnât change at all during the 1.5.0 â 1.6.0 upgrade. The before and after calllog report were identical. Thatâs good. That means the 1.6.0 did not mark a bunch of old calls as unread. Instead it appears that 1.6.0 changed the notification logic so that it now counts old calls that were already with new=1.
As you saw in my baseline report, I had lots of type=1, new=1 or type=2, new=1.
The fix:
So I then ran the same non-destructive fix @jppelt used to simply change the old call-log records from new=1 to be new=0
adb shell "content update --uri content://call_log/calls --bind new:i:0 --bind is_read:i:1 --where "new=1""
The phone icon no longer shows 9+ after that above command, post upgrade.
That should:
keep all your call history;
keep all contacts;
not touch SIM data;
simply changes the old call-log records from new=1 to new=0.
Now time to enjoy my phone
thank you
The culprit is this.
Mudita added voicemail notifications and on top of that added rejected calls notification which on the phone app still says Missed Call but android treats it differently.
So Mudita added rejected call notification but previous Mudita OS K didnât have rejected call notification, however people had rejected calls before. Update 1.6.0 comes, those rejected calls that werenât a notification become a stale notification that the phone app / mudita launcher doesnât clear even when you open recents calls.
Iâve tested this by downgrading the phone and mudita launcher apps to the previous version.
This can be fixed by an APK update of the phone/launcher. However Mudita still hasnât stopped the rollout, so this might be another bug like the Camera/Offline switch fiasco.
You know whatâs not mindful?
- Having to use adb/developer options/ or factory reseting the device to remove a stale notification.
Nice! Great you checked prior to the update. Not a programmer so I do not know why it appears to change all to â1â as a one time thing. Ever since I âclearedâ it, it works perfectly. And yep, grep would not work on windows.
does doing a factory reset delete your contacts?
Yes. And any pictures or files you might have - unless they are on the external SD.
Iâm glad you are getting involved as this is above my level. I rejected two calls recently after clearing but the badge did not come back on. Would that change your theory?
Because the new phone/launcher update knows those are fresh rejected calls and counts them properly.
The issue is during the upgrade the old reject calls (which werenât counted as a separate notification) were imported into 1.6.0. But the phone/launcher doesnât recognize them as âviewedâ.
So itâs specifically old stale rejected calls, not new ones. New ones (after the update) will be cleared properly.
How is it possible that the update is still being rolled out even though the first issues have already been reported here? Why arenât they stopping this, but instead letting even more users run into these problems? I think thatâs really irresponsible!
New releases will always have some unforeseen issues. If itâs an update that bricks your phone, I can see stopping a rollout, but not for something thatâs inconvenient or annoying but harmless.
Totally agree. The joy of the experience far outweighs the silliness of the 9+ shield. Apple iOS has had more than one failed updates - crashing and basically bricking the phones.
I honestly donât understand all the hate directed at the Mudita developers.
When I bought this phone, I was perfectly aware that I wasnât going to get the same level of smoothness, speed, and stability as a product like my (now unused) Google Pixel 9. Nobody forced me to buy this phone, and I have to say that it was one of the best things I could have done for my mental health.
In the past, I had tried using app blockers on my Pixel 9, but in the end my addiction would always shift to something else: WhatsApp, using ChatGPT, or even something as simple as endlessly scrolling through the photos in my gallery.
I had also tried buying a dumbphone, but with very little success.
With this device, however, I have finally been able to reclaim a little bit of my mental health. Sure, I donât have any particular needs beyond making calls, sending SMS messages, and using WhatsApp occasionally (itâs the only app I have installed), but that is exactly what I was looking for in a phone.
And the fact that a relatively âunknownâ team like Mudita is able to provide me with this experience is honestly fantastic. Sure, there are a few minor and annoying bugs, but I can live with them without any problems.
So, for whatever itâs worth, I think the team is doing a great job. Expecting a few bugs after an update is, in my opinion, perfectly normal. It happens all the time across pretty much every industry.
But that doesnât mean the product is a failure. Quite the opposite.
Nobody is hating the developers. What weâre hating is the stretch of 1 line of code fixes into a year of updates.
- The option to clear call history (which would have fixed this bug) is literally one line addition in the manifest.
- The option to uninstall apps (which should have been there from the moment they allowed third-party app installations), is literally one line addition in the manifest.
These have been added to the roadmap for 2026. Literally 2 lines of text, just so someone can say we provided X years of updates.
Bugs happen, the call number bug is no big issue at all to me personally I wouldnât even bothered to make a comment about it. What that bug speaks about is the lack of testing. A single rejected call from previous versions of the Mudita OS K and that bug would have been caught. A single one.
Iâm hitting a 1.6 bug which is even more severe than the phone notification problem:
Has the Update been pulled? Havent recieved it yet and want to be sure all the bugs mentioned above is fixed before i update.
I am curios to know about that too. My mac is waiting for macOS 27, so i have two excitements. I do not think i resist it. ![]()
I just tested this and strangely this doesnât happen to me, I can still turn Offline+ on and off normally. So once again there are bugs that affect some users, but not all. Mindfulness as usual ? ![]()
Legitimate frustration is not the same as hatred. Nobody is expressing that to anybody. I am sure Mudita will fix this quickly.
