MuditaOS K 1.6 Rollout Has Begun
@gezimos Really think they should hire you lol
I plead the fifth
Thank You! It works!
@gezimos is probably responsible for >25% of their customer retention lmao
Like many others here, I have also experienced the phone badge issue. I will probably apply the adb fix sometime, but that’s not what I’m writing about here.
Instead, my problem is one that maybe not many of you will run across, but I use Pandora to stream music while I’m driving, which worked perfectly in 1.5, but now in 1.6, when I bring up Pandora, it brings up a dialog titled ā€œAllow Background Activityā€, and instructions to go to Settings→Apps→Pandora→Battery and select Unrestricted. It also has an ā€œOpen App Settingsā€ button you can press to be taken there. The issue is that 1) MuditaOS K doesn’t have Settings→Apps→Pandora→Battery and 2), the Pandora App’s own permissions area (which is where the button takes you) doesn’t have anything related to this to set. The result is that without making these settings, it will stream fine for a little while, then cut off presumably when Pandora goes into the background.
Not sure if there’s a fix or work-around, but apparently, there’s something in the new release that triggered Pandora to want to ask for this permission.
I just noticed that the new update has deleted half of my wallpapers on the internal storage and half of my music files on the SD card. What the hell is Mudita doing ???
Deleted or not listing them in the apps? Two very different things.
Wallpapers and mp3’s are no apps, so why would they be listed there ?
The files are simply missing, but they were there before the update.
Has the rollout been paused? My phone still hasn’t given me the option to update. Or are the batches just very small?
Hi I have just bought my Kompakt and am setting it up. When I search for an update it says I am upto date with 1.5 and excuse my ignorance I cant seem to find the 1.6 version at present?
Kind regards
Ross
Hello there,
this just means that your batch hasn’t been rolled out yet. Give it some more time, in about 2-3 days at the latest you should have it. It will then show up when you check again.
thanks so much for replying have a good day
Same. We’re now 7 days into the rollout. @urszula, any idea when Mudita will hit 100% rollout?
Following…same problem here.
@YYZ This is an unusual situation. In this case, we would recommend that you reach out to our customer service for specific technical support. They will probably need to request your logs to see what happened behind the scenes for this to occur. They can be reached via email at [email protected] or, alternatively, you can submit a support request/support ticket directly on our website:
Nope, the batches are still going out. You should get it soon.
@Ross The rollout is still going out, so please be patient. You should get it soon.
And why, when so many users are having problems after the update? Why not pause the rollout of the update for now and make sure the issue gets fixed?
Exactly what I was thinking :rofl:
Which browser were you using? I can not make maps works properly on firefox (I downloaded the .apk from mozilla’s official website)
