No connection to Mudita Center possible
Hi, unfortunately I can’t connect anymore to Mudita Center from my Windows computer. On my Kompakt a USB-connection doesn’t show up either. No matter what cables I use, data transfer seems not possible. Hope this problem can easily be solved. Thnx!
Sometimes I restart the equipment and things start working. Power off the PC, restart it, maybe the usb port is inactive?
Thnx for your response. I’ve tried three different computers, but nothing works. There seems to be a problem with de Kompakt itself, but I have no clue how to solve it.
Can it be charged via USB cable?
Possibly it’s a defect inside the phone? Hope not. - contact [email protected]
Are you certain that the USB cable that you are using is NOT a charge-only USB cable?
Unfortunately, charge-only USB cables look like data-plus-charge USB cables!
#1 cause of this (in my experience) is the Kompakt not being updated to at least MuditaOS K 1.5. What version is your phone running now?
Thnx for your help, but I have the latest update and the cables are not only for charging. A few months ago, it still worked, but not anymore. I think I have to ask Mudita for support.
@hrvmaanen Sorry for the late reply. I’m just getting back from IFA in Berlin & digging myself out from all the messages.
What version of Mudita Center are you currently using? Are you using a proper USB cable (not just a charging-only cable)
Additionally, you can file a support ticket directly through Mudita Center & it automatically attaches logs to your ticket. This way our tech team can see what’s happening under the hood and causing issues.
Here are the instructions:
