Hey,
What is the expected Mudita Harmony accuracy? After 11 days of use, my Harmony misses the real time by more than 3 minutes.
Hey,
Hi @kubaaa we had some accuracy issues at the very beginning which we solved with a software update. Have you updated your Harmony to the latest soft with Mudita Center?
@kubaaa The latest version is 1.6.0
You can check the version installed in your device by clicking on SETTINGS & navigating to ABOUT.
Hey,
thanks for the quick replay. Yep, that was a problem. I checked the version and updated harmony from 1.5 to 1.6.
Thanks!
@kubaaa I’m glad that you got it all worked out. Let us know how you like the device after using it for awhile .
Even with 1.6.0 software update time is going few minutes ahead after some time (it is not as bad as it was but it is noticeable after month+) like I wrote here Initial Mudita Harmony Reviews - #148 by lamma
@lamma That’s an interesting observation.
I’m curious if any other Mudita Harmony user has experienced this.
