MK Volume+ review by chadp
MK Volume+ — Community App Review
Version: 1.1.0
MK Volume+ is a small utility for the Mudita Kompakt that raises the maximum in-call volume beyond the stock setting.
It provides up to approximately +6 dB for the earpiece and +7 dB for speakerphone. Earpiece and speakerphone boosting can be enabled independently, and an optional setting reapplies the selected boosts automatically after a reboot.
MK Volume+ affects call audio only. It does not increase the volume of music, podcasts, videos, alarms, notifications, ringtones, or other media playback.
The app uses louder gain values already present in the Kompakt’s MediaTek audio calibration map rather than modifying system or vendor files. It does not require root access, an unlocked bootloader, or permanent system changes.
Because it allows output above Mudita’s stock maximum, excessive use could cause distortion or speaker damage. Use your best judgement.
GitHub / source / download:
Direct v1.1.0 release:
Review for version 1.1.0
I published v1.2 today that adds localization with support for Polish, Dutch, French, Spanish, Portuguese, and Italian. Translations are from LLM so please let me know if something looks wildly off.
Review updated by @chadp
  • Version: 1.1.0 → 1.2.0
  • APK Link: https://github.com/chadchad4423/MK-Volume-Plus/releases/download/v1.1.0/MK-Volume-Plus-v1.1.0.apk → https://github.com/chadchad4423/MK-Volume-Plus/
  • Checksum: 45609976cc69037ae932406d1c3669d9377a3fdbbeea69667a400aa90bb574db → ``
View current review
Review for version 1.2.0
User rating: ★★★☆☆
Is there something I need to turn on or off cor this app to work? I feel like sometimes it does not work, sometimes it does work and the phonecall is really loud.
Hi @nico.n - I haven’t seen any inconsistent behavior from the app, but please let me know if you notice any trends of when it is (or isn’t) boosting the volume. That will help me pin down what’s not working.
