Katapult Launcher v1.3 ( with Lockscreen Notifications)
You are the GOAT!
Hehe, I do have a bug.
On the Home page, with extra row, long app names are now displayed on two lines (in my case “Proton Calendar”. It was not the case with 1.4). That second line forces the icon to move up and so icons are suddenly disaligned. Not problematic but not aesthetic on your main home page. The problem doesn’t appear in “all apps” (long name are truncated)
Uuuu thanks for catching this, I’ll be honest I rename stuff like Proton Calendar to just Kalendar :smiley: so I missed that bug. With this I caught another bug that renaming requires to refresh the homepage after u do it!
Will fix this in the upcoming version :slight_smile:
Does anyone know how to clear bluetooth notifications? I recently paired my Kompakt tu my car’s bluethoot and since then I’ve a bluethoot notification on my lockscreen, but I can’t find a way to remove it :slight_smile:
Katapult Settings / Notifications /
  • Notification Log
This shows the hidden android utility and it lists all the notifications there. It should show the app that is giving you a bluetooth notification, you can tap on it, and then it should give you options to disable notifications for that.
Thanks! I discovered that if I turn off the bluetooth, the notification disappears instantly. But if I turn it on again, the Kompakt shows it again. It’s weird
yess yesss YES!!
@gezimos
Wow, in Katapult 1.5 you can change the icon size to 80 x 80 :slight_smile:
Thank you so much! Now the launcher is perfect for me.
If you read it here I even tagged you because it was your request :slight_smile:
Thank you, glad you think so!
A new small release with a few bug fixes will come soon, nothing major. (but now the app has its own updater so I don’t mind making small upgrades).
I noticed that the clock widget is now positioned higher up. Presumably, this is to make room for the second row of icons when you set the grid to 80x80. However, the clock slides down a bit when you enable the battery indicator above it or when the alarm clock is displayed. That position looks better, in my opinion. Maybe you could set the clock widget to be positioned a little lower by default—in the exact position it’s in when the battery indicator is also displayed.
One more question: If I disable the clock in the status bar, I have to enable a service for Katapult. Does that use more battery?
Yeah it’s centered between the music widget and top of the screen, because with statusbar hidden it looked too much off. Status-bar is already white so it looks more balanced. Consider enabling the weather and it will be there to push the clock lower :slight_smile:
No battery impact. This just draw a white rectangle over the status-bar clock
(Katapult v1.5) Maybe it’s in there somewhere and I’ve just missed it, otherwise please add it to the wishlist:
Is there a way to “Force stop” all apps (Katapult will of course re-start immediately)?
(What I’m actually looking for is the equivalent of the [Android multitask]-“Clear all”, which closes all opened apps but of course doesn’t force-close the launcher.)
What I’m doing now, is [choose inkOS], [swipe → for Recents], [longpress on everything, and Force close the necessary ones one by one].
Force Stop for all is not possible as it is a system privilege.
Clear All option that exists in Recents menu of every android phone is part of the defaykt Launcher (usually called Launcher3 + Quickstep). Mudita has scrapped that from the AOSP.
You can do this in Katapult as well. But a bit differently.
in All Apps page:
Longpress an app → App info → Force Stop
For home apps you can set a quicker shortcut:
katapult settings → Gestures → Longpress in home → App info.
This will change the long-press behaviour in home, it will open the App info menu directly when u longpress in one.
Mhmm, that’s the way I do it if it’s just a few apps that I know that I’ve opened.
(The reason for going via inkOS, is that it gives me that “Recent”-list - instead of longpressing on :sparkles:everything​:sparkles: in “all apps”.)
It’s for the Mudita OS K wishlist instead, then. (@urszula :see_no_evil: )
Maybe something in Settings → Manage Apps? Or a per-app-basis: unused: timeout/no_timeout?
Useful from a battery saving perspective, if I’ve understood things correctly?
→ I’ve also noticed that if I open a (sideloaded) app, go to “home” [launcher: Katapult], then re-start my Kompakt, the app still gives me the “Force stop” option, i.e. it has not been force stopped (or has it been background-started again?) by the re-start. :anguished_face:
Idk if this helps at all in Settings / All Apps / you can sort the all Apps list to Most Recent or Most used in addition to Alphabetical.
I know some users would benefit from some of the extra features that inkOS has, but I’m trying to keep Katapult simpler.
Love the launcher! I installed v1.5 yesterday, and ever since the phone app is showing a little ‘2’ badge. I do have two missed calls but that was days ago (even from before installing Katapult). How do I clear this? It stressed me out haha
Edit: never mind, found it! Now I can go back to being calm :wink:
Me again! After using Katapult for a few days, I switched back to using the stock launcher. I felt like it significantly slowed down my device. Does anyone else have that experience? And can something be done about it? I did really love a lot of the functionalities that came with it, and the overall look of it, so it would be a shame if I cannot use it anymore.
Great launcher! Do you think there is a possibility of adding a text/list based home screen?
This is the first report that I’ve received for making the device slower.
I’ve noticed zero slow downs on this, and I measured memory use.
No sorry that is not possible, Katapult will remain as is.
Use my other launcher inkOS if you want tex/list based.
