inkOS v0.4 update
Will this work for ANY 3rd party app, or only for selected messengers ?
Hey, just wanted to say I have been using InkOS for about a month so far and really love it. Thank you so much for your work to develop and bring this to our community! However, I have had one major bug which appeared when I installed it – my SMS notifications no longer make any sound. Calls still come through with the regular ringtone, but I have to check my phone periodically to see if I have any messages. I have checked every setting I can think of to no avail. Appreciate any advice you can offer whenever you get the chance - it’s not an urgent thing but would definitely be nice to fix.
I’m glad you’re liking the launcher!
This is not related to inkOS, because it has no system privileges to cause notifications to have sound or not.
Have you tried clicking the :gear: gear icon that appears near the title of a notification in Letters or Simpletray pages. And then see if you might have accidentally turned-off the android notifications for the SMS app, which would cause for you to have no sound.
Hope this helps
@YYZ They will work with any 3rd party app, same as they do in inkOS notifications. inkOS will simply forward them to the lock screen.
Great! It seems v0.5 is going to be awesome :slight_smile:
Hey Gezimos, I just finally gave it a try and I’m loving it.
There is just one thing I don’t fully understand.
Quick tray (that appears e.g. when you tap the notification bell by default) versus “Letters” - it seems that they are not fully in sync when comes to notifications. Sometimes they don’t go away when an app is finally read.
Honestly I’d prefer getting rid of using the Quick Tray completely and having Letters apear upon the bell tap. I prefer that one as the main notifications view. Is that doable?
Very happy to hear that, thanks for giving it a try
Yes they’re not synced on purpose. Because Letters caches the notifications, simple tray on other hand is dynamic and it responds to the app or android and clears the notification.
The idea behind Letters originally was to be able to read notifications at your own pace, without having to open the app at all. Also it was like a defensive function to catch notifications that the default apps (for example the phone app) were removing.
There is an option in Notificaton Settings called “Clear when app opens”. So it will clear them and kinda “sync” them with the Simpletray/home.
You can remove the quick tray by changing the swipe down in Settings / Gestures to something else or to “disabled”.
Believe me we’re in the same page, yesterday I was tapping on it and realized that not all people want to use the SimpleTray, and some just prefer the cached Letter notifications. So i’m thinking of adding a switch to allow the user to choose which type of notifications should the counter show. So it should come with the next update.
Again, Dziekuje for the coffee :slight_smile:
Hi Gezimos, thanks for the upgrade, one question:
How do I remove the wallpaper from the screen?
To hide the wallpaper you can change the Background opacity to 255 (it makes the wallpaper opacity 0).
But if you also set the lockscreen wallpaper, it might still be visible sometimes so for that you can use this empty white image below and set it as a wallpaper/lockscreen and it will. be fully gone.
In the next version i’ll have a preset directly on the app so users won’t have to do this.
@gezimos: Until I get my next Kompakt (previous one sold last year due to missing features), would you recommend that I install and play with inkOS on my AOSP-16-based (deGoogled) cellphone so as to learn more about inkOS?
@kirkmahoneyphd When are you getting the Kompakt again? I should release v0.5 soon with some changes.
But you can always give it a go now, its core will remain the same just a more user-friendly navigation and more customization will come in the next release.
I do use it on Android 16 on my qwerty phone. In a degoogled phone shouldn’t have any issues.
I’ve been wondering if inkOS can (or will be able to) also install .xapk files ?
Thank you! I am unsure when I will get the Kompakt again. Having seen your preview of v0.5, I will wait until that release to try it on my AOSP-16 cellphone.
Hello there! I absolutely love this update, you have done great work. Now my homescreen looks exactly like my personality and so cozy :slight_smile:
I have a suggestion as I am used to that feature on my smartphone: perhaps you could add either a camera icon or sms in the right corner (or left if your apps are alligned to the left) for constant quick access? It would be useful if you just need a quick snapshot or need to text/call someone really quickly so it’s always at hand. Maybe the user can decide if they want that at all or not and which app they would put there.
@YYZ No that is not possible, it’s out of scope for a launcher.
@kirkmahoneyphd No problem! Will post an update on this topic when it’s on, and I might make another video on how to use it.
Share a photo of your phone/homescreen :slight_smile:
Well good new for you this has already been added in the v0.5. The quote widget area has been turned into a bottom widget area. (you can still leave it as a quote).
It will have some simple widgets and one of them is icon shortcuts, with a few preset icons to choose from but you can wire them to any app you want.
Icons are resizable with the same quote font size. Here i’ve shown a center theme, with 2 shortcuts but you’ll be able to disable either the left or the right.
This launcher is just so freaking good.
Best launcher, and definitely the best app for the Kompakt. Can’t wait for the new release!
This is just what I currently have but I plan on drawing a background myself, with a similar floral/pomegranade thing :slight_smile:
Looking forward to the new feature!! You have already outperformed my needs and suggestions for this app! It’s so sleek and wit so many options for customization :blush: Cannot wait when Mudita releases the lockscreen customization, then it will be top-notch.
Your screen looks very nice. This just reminded me to post a trick I learned how to make the home work better with wallpapers.
Left is normal mode, right is with High Contrast mode turned in.
To turn on high contrast mode you need;
  • Developer Options, scroll down to “smallest width” edit it to at least 420, but keep in mind the original value or write it down somewhere.
  • Then in Developer options search for “High Contrast”, now you’ll be able to scroll to the last item in the menu and enable “High contrast”
  • After that go back to Smallest Width and change it back to its original value.
This in turn will add some “border” either white or dark to text that it finds it has not enough contrast.
However this will work only for text, not for icons and other ui elements.
One thing I noticed though: when I launch KillApps, it always shows inkOS as running in the background, even after I killed it. Next time I launch KillApps, it’s there again. What could be causing this ?
