@jrbalzer Welcome to the Mudita Forum. We are glad that you’re here. I just want to confirm that YES, full group message support is coming in the next update which is are planning to start rolling out towards the end of November.
“If you sideload olauncher or even Niagara Launcher and make it your main launcher, then you can see the sideloaded messaging app instead of Mudita’s app”
Great. Here you have to know about, find, download, install, and run a third-party app to run another third-party app you have to know about, find, download, install, and run - in order to get the Kompakt to do what they told you it would.
“YES, full group message support is coming in the next update which is are planning to start rolling out towards the end of November.”
Would that be the 1.6.1 version OS?
The one that after it’s updated STILL says 9+ unread SMS messages on the lockscreen?
Full Group Messaging Support was launched last year with update 1.4
If you’re running MuditaOS K 1.6.1 then your Mudita Kompakt has Group Messaging support. All you need to do is enable Group Messages in the settings:
If you’re still getting the unread message label on your phone, even after updating to MuditaOS K 1.6.1, please reach out to our tech support at [email protected]
They will most likely request logs to check what’s happening behind the scenes for you to still be seeing these notifications.
