Finding Battery Usage by App on the Mudita Kompakt?
I’m trying to figure out if there’s a built-in way on the Mudita Kompakt to see which apps are using the most battery. I’ve looked in the regular battery settings, but I can’t seem to find a detailed battery usage breakdown by app. Does anyone know if this feature is available somewhere in the settings, or if it’s hidden under a different menu name?
UPDATE: I was able to find a menu called “Use Battery Manager” under the “Settings Search” shortcut and toggled it on but still cannot see battery usage broken down by app. I believe it may display the requested information over time as it gathers info but am not sure yet…
@stevenjc123
Are you using the naive launcher? Or InkOS because I can’t find “Setting Search” in the settings.
I’m using InkOS.
@stevenjc123 That makes sense because we don not have this in the native Mudita launcher, but I did pass it on to the team.
A post was split to a new topic: Planned: Battery Usage Manager
