➡️ Planned: Battery Usage Manager
I’m trying to figure out if there’s a built-in way on the Mudita Kompakt to see which apps are using the most battery. I’ve looked in the regular battery settings, but I can’t seem to find a detailed battery usage breakdown by app. Does anyone know if this feature is available somewhere in the settings, or if it’s hidden under a different menu name?
UPDATE: I was able to find a menu called “Use Battery Manager” under the “Settings Search” shortcut and toggled it on but still cannot see battery usage broken down by app. I believe it may display the requested information over time as it gathers info but am not sure yet…
No built-in way as far as I know, but you could use this app https://play.google.com/store/apps/details?id=com.gsamlabs.bbm&hl=en_US
