WhatsApp Help! No Notifications, Only via WiFi
Hey everyone, WhatsApp calls and alerts only come through when I’m connected to WiFi. So when I’m out walking, and people call or text via WhatsApp, it doesn’t come through. Only when I connect to Wifi and open the app do I see new messages and missed calls. Has anyone else experienced this problem with their Mudita Kompakt? It never used to happen, not sure why the change. The phone has the latest software and has been restarted multiple times… Thanks in advance, J
Can you check if your data connection is ON & enabled?
Hey,
Mobile data on my Mudita Kompakt has stopped working. Calls and texts work fine, but nothing that needs data works unless I’m on Wi-Fi. WhatsApp messages and calls only come through once I’m back on Wi-Fi, even with the app open. It used to work, and the phone is on the latest software.
I’m on giffgaff (UK), which runs on the O2 network. My giffgaff account has an active plan with 4 GB of data available, so it isn’t a credit or allowance issue.
What I’ve noticed and tried:
  • Mobile data is switched on, and the phone has been restarted several times
  • Network selection: on automatic, or when I select “giffgaff”, I lose all signal. Selecting O2-UK manually gives me bars and LTE, but there’s a “!” next to the bars and no internet
  • The APN list only offers O2 Pay Monthly and O2 Pay As You Go, with no giffgaff option. I’ve tried both, and reset the APNs to default
  • I created a giffgaff APN (giffgaff . com / gg / p, MCC 234, MNC 10). When it’s selected, the signal bars disappear completely
  • I edited the existing O2 APN to the giffgaff details instead. That keeps the signal but still gives no data
  • I’ve tried authentication type PAP, APN protocol IPv4, and switching the network type between LTE and 2G. The “!” shows on both
It looks as though the Kompakt isn’t recognising or handling the giffgaff SIM properly. Is this a known issue, possibly since a recent update? Could you tell me the correct settings to get data working?
Thanks,
J
What MuditaOS K version are you currently on?
OS K 1.6.1
Have you reached out to your network provider to check if it might be an issue on their end? I recall another user with a similar case where the network provider had to reset something on their end and everything worked after that?
