Hi, I just bought a Mudita Kompakt and sideloaded Whatsapp into it. So far everything works great, except that when I make a video call I get a black screen and my camera doesn’t turn on. I downloaded it through aurora store and also tried the APK from their website but the same thing happened. Is there any way I can fix this. Thank you.
Mudita Kompakt does not have a front-facing camera, so you’re not going to be able to make video calls in the way you normally do, with a front-facing camera. WhatsApp is trying to access a non-existing front camera as default.
However, you can manually switch the camera, but it may not be comfortable because then you cannot see the other person.
Thank you for your answer. I tried switching the camera, but nothing happens. I get the same black screen as in your picture. I also noticed the camera button appears to be off (you have the same thing in your photograph), and trying to press it does nothing.
