I am considering switching to the Kompakt. I am assuming I will need a few sideloaded apps which I would install through the aurora store. However, I want to avoid the distraction of being able to easily add new apps through aurora. Is it possible to un-install the aurora store so that a separate device is required to re-install aurora and add new apps?
the Kompakt by default doesn’t come with the aurora store you have to sideload it through the Mudita Center.
if you don’t want to have distraction either you can directly sideload the apps you need without installing aurora store in the first place
Or, you can first install aurora store install the apps you need and uninstall it afterwards.
I second @devamjaglan except that to uninstall apps you’ll need to use adb, unfortunately. (unless I missed an update of Mudita center?)
I would chime in & add that some apps will need to be updated from time to time & if you have the Aurora store avail. it makes it much easier, instead of having to upload the new version of the app on your phone with every update.
Thank you all so much. I think I’m ready to make the switch!
@pazen The sale we have on now, ends this weekend, so make sure to order your Mudita Kompakt soon ![]()
