Timer & Stopwatch review by jppelt
Timer & Stopwatch — Community App Review
Version: 1.4.3
A simple timer and stopwatch.
Review updated by @jppelt
  • Description updated
View current review
Review for version 1.4.3
User rating: ★★★★☆
Very cool! This is awesome and was sorely needed. I read through the known issues (thanks!) and in my testing, it seems to work exactly as expected. That said, I’d suggest:
  1. For custom timers, it’s kinda crazy to have to tap potentially 60-99 times to get where you want to go. IMHO, implementing custom timers practically demands at least one of these:
    • support keyboard input
    • provide a phone-style numpad on the screen for typing in the time (like stock Android timer)
    • have +/-5 and +/-10 buttons
  2. When setting up the timer, it would be great if the presets for 5, 10, & 25 min could either be extended (3m, 15m, 30m, 45m) or even better: made customizable. If you replace “min” with “m”, you could fit 4 or 5 buttons instead of 3. This would be less of an issue if you implement #1.
  3. Far less important than either of the above, but once a timer is running, I wish it was possible to extend. Adding a +1m button (like stock Android timer) is one way to do it.
Thanks for taking the initiative to make this and share!
Thanks Ryan! I’m on the road right now but totally get where you are coming from. I’ll see what I can do a little later this month. Especially the potential tapping.
Fingers crossed. Thanks for the great feedback.
  • Version: 1.4.3 → 1.5.2
  • APK Link: https://github.com/jppelt/mudita-timer/releases/download/v1.4.3/mudita-timer-v1.4.3.apk → https://github.com/jppelt/mudita-timer/releases/download/v1.5.2/mudita-timer-v1.5.2.apk
  • Checksum: 7a6c046552ce975a51240f5ee0c0d2b8aa466ca3077cf5eddfe34edaf7e793e9 → 4db2a8115f4b3b7f93713f115e822e23a164335133bc2ddee3691f88c61a871f
View current review
Review for version 1.5.2
Hi Ryan,
Thanks so much for the thoughtful feedback.
I just pushed v1.5.2, which adds your #1: custom times are now entered on an on-screen numpad (fill-from-right, like a stock phone timer), so no more tapping to get where you want to go. That also takes a lot of the pressure off your preset suggestion (#2), though I’ve noted it.
Your #3, extending a running timer with a +1m button, I like it and it’s on the list for a future version; I left it out of this round to avoid disturbing the alarm/background logic I’d just gotten stable.
Grab v1.5.2 from the Releases page whenever you get a chance and let me know what you think.
Thanks again,
JP
