So on my mudita pure I have a semi-stuck key. I noticed it quite early on (November last year) and it seemed to have fixed but now it’s back to being really hard to get the text to show up – I have to press super hard to get it to work – and it’s the “0”/space bar key, haha.
Has anyone had this issue or know how to fix it without potentially breaking the phone?
I had a few squeaky keys and one semi-stuck when my Pure first arrived - a short time later the Mudita team had replaced the unit for me and huzzah! No problems since!
Good luck with your key!
Ah, so you had to get yours replaced?
Oy! Sad to hear this @grilledcheesebb , let’s see if @Grzegorz_Szmidt has a solution in mind or if we’ll need to go through the official Support channels.
Thanks for sharing your experience @galtions
I think our Support team is awesome!
Yep, once I figured out it was the phone and not my thumb making the noise…
I hope there’s an easeful solution for you…
Hi,
Okay! I’m not sure what the warranty period is. Do you want to take this to DMs @aleksander?
Hello There! Please send an email to support@mudita.com and we will see what can be done. We will check your warranty to confirm if you are eligible for a replacement.
It seems Grzegorz beat me to it
Keeping my fingers crossed @grilledcheesebb
