When using Whatsapp I keep getting the default Mudita keyboard which is a hassle for me to use (especially regarding spelling suggestions) I cannot access the system → language and keyboard tab anymore in the same way as before. Neither on 1.4 or 1.5. It only shows standard Mudita Keyboard and not anymore the Heliboard toggle. I did access this through developper options but somehow Whatsapp does not catch it. Brave Browser for example does. Then I disabled the Mudita Keyboard with adb but even this makes no difference for Whatsapp.
How to solve this? It would be nice to have the previous options again in the language and keyboard tab. How do I make Heliboard the system default?
Workarounds to access the setting to de/activate different keyboards, which disappears in the normal settings after choosing the Mudita keyboard:
With the app Activity Manager : search “settings” - search “keyboard” - choose “Settings$AvailableVirtualKeyboardActivity” and you get the dialog to de/activate the different keyboards.
With the app Unexpected Keyboard: When you start the app, you can activate and choose a keyboard.
Btw. Unexptected Keyboard has a eink-theme.
On my MK I can use different keyboards with WhatsApp.
This setting disappeares the moment you choose the Mudita keyboard and its settings.
I tried it with Thumb-Key, the keyboard I normally use, and I can’t access the setting. For that reason I use Unexpected Keyboard, which gives access to the setting to choose the keyboard.
Thank you for the replies. It still does not work on Whatsapp. Mudita keeps launching the stock keyboard. Another issue is that it launches the stock keyboard without accepting changes to the settings. I live in Belgium and we have AZERTY. The stock keyboard does not change to AZERTY on none of the apps, not on Whatsapp but also not on the native SMS app. When I changed the system language to Dutch it makes that I get Dutch spell suggestions, which helps, but still it does not accept the AZERTY nor other settings such as spell correct adjustments. In SMS no spell suggestion is present at all.
Does anyone know the device IME ID? So I can try out some things with ADB, I cannot figure out the correct IME.
@urszula Does the team have any info on this matter? I don’t see similar reports. This issue has effect on the native applications as well as side loaded ones.
I asked google: “for dutch keyboard setup what is the mudita kompakt device IME ID?”
The Mudita Kompakt does not use a typical “IME ID” to set up a Dutch keyboard. Instead, MuditaOS K 1.5.0 has built-in support for the Dutch language with native QWERTY and AZERTY layouts, which can be configured straight from your keyboard interface. [1]
might need to contact mudita support
Let me see if I understand your issue correctly: You have set your Native Keyboard as AZERTY- but it’s not being recognized by sideloaded apps? Just so we’re on the same page Mudita Kompakt features multiple keyboard layouts including QWERTY, QWERTZ, AZERTY, Dvorak, and Colemak (this is new with the 1.5.0 update).
Yes and not only with Side loaded apps, also with native SMS app. It does not accept changes in my settings. So in SMS when the original Mudita keyboard is activated, it stays in QWERTY and English spell correct. While in my settings, it is AZERTY and with Dutch spell correct. So basicly the default keyboard setting is at work and settings are not affected.
Another thing going on is that, some side loaded apps to accept the Heliboard when I activate it and some do not. If the Mudita keyboard could be fixed, atleast I have AZERTY and Spell correct in those apps. Now it is very annoying to type in Dutch and having to constatly remove the auto correct function that is on default.
I now just realized that the Native Mudita keyboard issue might be caused by an ADB command I used a few weeks ago to disable the phone keyboard settings in order to try to make it possible to have Heliboard on all apps. To reverse it I need the settings IME ID so I can try out an ADB command.
Okay so I managed to reverse the ADB commands. Found the IME with adb shell pm list packages and adb shell ime list -s. Did not fix the issue but a simple thing that was not so obvious in the keyboard settings is that to activate costum imput styles I had to disable ‘use system languages’ and that made it possible to enable the AZERTY and Dutch language.
So that’s all good. Only frustrating part is that some side loaded apps like whatsapp still do not accept the changes in settings … so no progress on that issue.
