Problem by importing pictures from MK
So, I related that in another topic about the same theme but haven’t received an answer yet. This is a second try.
By importing the pics on the Sinology Photos from my NAS server I have 2 problems:
  • if I select more than 2-3 pics at once, the import crash. That doesn’t happen with my camera so I think the problem comes from my MK
  • After import, some pics appears in Sinology like that
  • But if I import it from Sinology to my iPad, it’s ok
Any thoughts?
@shadock I’ve no particular help for this because I don’t use Synology, however I’ve noticed transferring photos via Mudita Center is very slow so I stopped using it after a few tries. Plus on mac it takes ages to open since it’s not a native app.
  • For usb transfer I’m still using OpenMTP, not the greatest UI but it’s fast and you can see all the folders.
  • For wireless transfers LocalSend (which is still faster than MuditaCenter wired).
But I can’t transfer photo from the center.
My MK has to be connected to my computer and have to appear in the files navigator. For that I have to restart it once plugged in.
With the Center I only have the opportunity to delete the photos.
The USB connection is a bit quirky, even with OpenMTP it’s not recognized in norma mode. Only through Legacy mode. And somehow it conflicts with apps like Dropbox, OneDrive which have to closed in order for the Kompakt to be connected.
But with the OpenMTP you can add photo and delete photos too, and very fast too
Sorry but for me you’re speaking Chinese.
The only app I use out of the native is Signal.
I try too use the phone as it is build.
But thanks for trying to help
You install OpenMTP on your computer not on Mudita Kompakt.
OpenMTP is an opensource app that allows your computer to connect to android devices and see all the files/folders.
With OpenMTP you can add files and remove files from your phone. Basically like Mudita Center but let’s you add/remove photos, music or whatever.
You don’t have to install anything on your Kompakt.
How that’s interesting.
So I could add ringtones? Miss the ones of my MP02…
And eliminate the vibrate of the alarm? Because it annoys me.
Thanks a lot for your help and have a nice day.
Technically you can add Ringtones but MuditaOS currently doesn’t allow custom ringtones, only the one preset by them.
No you can’t touch any phone settings, it’s just a file management tool for Android phones.
Damned.
So no big interest.
But thanks for your answer.
Hello Shadock.
I have the same problem. I can only delete pictures from the Mudita center. I cannot see them or access them.
I can load the pics using a photo application (Sinology Photos for me), the secting « add » the searching my MK in the files search of my computer. Pics are in the DCIM folder of the MK.
But to see the MK on the computer I have to restart it once it is plugged.
