➡️ Planned: Voicemail notification to U.S. customers+ Long Press 1 to dial VM
I believe that this should be listed under Mudita Kompakt > Planned, as there have been many discussions on this Forum over many months about this issue, plus it is on the roadmap for Q3 2026:
#Kompakt
“Thread 1” link to https://forum.mudita.com/t/no-voicemail-notification-on-mk/8686
“Thread 2” link to https://forum.mudita.com/t/is-this-the-end/14737/33
@kirkmahoneyphd It’s already listed as planned in the main thread:
I believe the request in planned is only for dialing voicemail, while Kirk’s new posts include the additional enhancement requests, namely notifications.
@adizzy I will ask the team to clarify
@urszula, yes, please ask. Long-pressing [1] to access voicemail is NOT the same as getting a notification about new voicemail.
Might we get an update to MuditaOS K (now at 1.1.1) so that we can press [1] on the Kompakt to dial our carrier’s voicemail number?
Coincidentally, I asked this same question three years ago about the Pure. But, I never took possession of a Pure cellphone, so I do not know what happened with respect to the Pure.
Here is that post with the same question:
When I press [1] on the Kompakt today, the call ends almost immediately, and I see this:
In contrast, when I call my USA carrier’s voicemail telephone number, I am able to reach voicemail, and the word “Voicemail” – which is NOT in my contacts list – then appears at the top of the Phone app’s “Recents” tab:
That “Voicemail” item on the “Recents” tab is usable. But, once Mudita makes it possible to clear the “Recents” tab, it will disappear. Yes, I can create an entry in my contacts list for my carrier’s voicemail number, but dialing voicemail in this way will require finding that entry each time in the contacts list.
Being able to press [1] to reach voicemail would be the best way to do so.
Thanks for your attention to this!
@urszula: This entry does NOT link to a thread about voicemail notifications to U.S. customers:
Might I recommend that the team EITHER add a second entry about “Voicemail notifications to U.S. customers” OR change the Request title (e.g., to “Voicemail enhancements”) and change “Forum thread” to “Thread 1” and add a “Thread 2” that links to https://forum.mudita.com/t/no-voicemail-notification-on-mk/8686?
Thank you!
@kirkmahoneyphd Since you mentioned PRESSING #1 for VM earlier in this thread- I will leave that in here & just add to the topic. I just confirmed with the team that the next update will have VM notification as well as the function to Long-press ‘1’ on the dial pad to instantly call voicemail. If the voicemail number is unassigned, you’ll see a clear notification
