Photo problems with Mudita Center
This feels pretty silly to ask, however what is the best way for me to export the pictures I take on my Mudita? I have seen some others make comments on this, perhaps the problem is I am using a new macbook air. Can Mudita Center make an update to the app that we have?
You can use image capture that comes preinstalled on your mac. I think Mudita will make an update to make it possible to export pictures from Mudita Center but in the meantime, image capture is the easiest way on a mac.
Thank you! I’ll give that a try
UPDATE: Our team is working on updating Mudita Center, so that you can view, export, download & delete the pictures on your Mudita Kompakt.
Is this coming in July update? I have only mac and OpenMTP just not work for me
@beyondgravity I’m going to ask our team. I know that music files will be able to be added for sure. I will ask about pictures.
From the Center I can’t export the pics
But when the Kompakt appears mounted on my computer (for that I have to restart the Kompakt when connected, other way I can’t see it) then I can import from Sinology Photo.
But only 2-3 pics at once, more I have a crash… Think that the problem comes from the Kompakt as I don’t have that with my camera.
Other, sometimes the imports look like that
Curiously, if I download it from Sinology Photo to my iPad, it appears normal.
Very painful that all.
