@thilodus You might have inadvertently turned it off. Try pressing #31# and see if it turns back on. That’s the MMI code to turn the caller ID on.
MMI codes are entered like telephone numbers to obtain a variety of information as well to enable and disable various actions.
For example: If you want to hide the caller ID dial *31# and press call button.
Thanks. Works now. But I am sure, I did not change it inadvertently. The transmission must have been turned off by default. In addition, the user should be able to switch the transmission on and off without having to enter a cryptic code.
@thilodus You’re right. I don’t think it’s by default though because on my Pure didn’t have this issue.
I’m curious if any other users have this issue. I will definitely bring this up to the devs to see if this is something that we can add to the list of features.
