I am a bit puzzled about the notification behavior of the mudita kompakt.
I installed beeper to bundle my chat clients.
I want my mudita to only vibrate if I get a notification. Is this possible at the moment?
I am aware that there is no notification on the screen(I have Niagara Launcher for that) but at least I want to get a vibration if there is something coming in.
Edit: When I open the Beeper app I get the vibration. Looks like the app is not running in background.
ok cool. Thanks for your Feedback.I did not found it. If it so easy would be great if you can send it to me. A lot of stuff but did not found a way to enable the app to run in background.
I couldn’t get beeper notifications to work either. I believe beeper’s notifications run through google services, and the Mudita Kompakt is completely degoogled. For comparison, I’ve found Whatsapp notifications work as they don’t seem to need Google.
Too bad I thought I could save the hassle of moving the apps and use beeper. But then I migrate Signal to the kompakt. Whatsapp notification where muted anyway.
OK, so I thought this was working, but then I had to factory reset and I wasn’t able to get push notifications or Kindle working again after re-installing microG.
Sorry, I guess it’s back to the drawing board for now. Gonna hold out for an official Mudita or Beeper solution.
