Not Receiving Texts
I’m glad that at least this issue is being handled but I’m a bit confused here, being that I am using a NA device in NA. Are you suggesting mine and astratev’s issues are not related despite the presentation being near identical, simply because my Kompakt is the NA version?
Yes, they are longer. Thanks for the clarification! So I am having trouble with receiving all of the MMS.
Hope this helps the Mudita team.
Just adding that I am on the NA version, Using Quik until group sms is supported, have had 3 confirmed missed texts.
The one missed lastnight was only 83 characters (including spaces)
Misses from iphone and android senders.
UPDATE:
Our team did some digging & here’s something to check, for all those who are not receiving all texts (randomly missing texts in a thread):
The cause may be DUPLICTE CONTACTS-
  • They might be visible in Contacts app - but that is not always (you may have had some contacts stored on the SIM & the added another one manually.
  • They might be hidden in Contacts database - and are currently not fixable until you factory reset your phone and import contacts correctly.
  • country codes, area codes such as +48, +0 and 048 might be additional issue here. In the US if a phone number is (312) 123-4567, but you have it saved as both at +13121234567 & just 312124567, that that may cause issues.
  • Google Contacts import may complicate this as well.
  • As well as WhatsApp messing up and injecting its values to Contacts database can cause these issues.
Thank you Urszula,
Can you confirm if I factory reset the phone and reload from the back-up, will it just reload the conflicting contacts? I will test this later tonight, but don’t want to just report no fix if my reload from back-up will just re-introduce the offending contacts.
@tigergarden I’ve asked the team to see what will happen if you did what you described above.
