Not receiving 2FA text message
Hi, I just tried accessing my bank account which send me a code by text as a part of their 2FA but my Kompakt doesn’t receive them …
It seems like it doens’t recongnize text messages from phone numbers that have only 3 or 4 numbers. I also tried the option of receiving a phone call giving me the code to log in, thus my Kompakt rejects the call when I answer it …
I hope this can be fixed very soon in an update as this would make the Kompakt unusable for me if it can’t receive my 2FA text.
Thanks
Gabriel
@gabriel_lafr Thank you for reaching out & bringing this to our attention. I have not seen/experienced anything like this. I regularly get text messages (incld 2FA) from non-standard numbers. I will ask our team as to what could be causing this.
Thanks for getting back so fast ! I hope the team will be able to find out what’s going on. I already tried rebooting and removing/reinserting the sim, but I had no luck
Interesting. I get my two factor messages and calls, but I just checked and all of mine used five digit numbers rather and 3 or 4.
My bad, mine are also mostly 5 digits normally (sometimes 4 digit).
What’s the weirdest is that the phone hangs up when I answer a phone call to receive a code. I’ll try out some things, if it doesn’t work out, I’ll factory reset it to see if that fixes it.
You can always insert the SIM to another phone
Got it fixed :+1:, the issue came from my service provider
Enjoy the phone!
@urszula Perhaps it is of value to keep track of issues and known solutions in an excel file? At times I see the same issues coming up on the forum with the same solutions.
@anon4838315 Thanks for the suggestion- we do have a space where we do keep this info (for company use) because people also contact support directly, before they post on the FORUM & it helps when the guys know this info as well.
Great. At times I try to help you guys out with customer questions but my time is limited too.
@gabriel_lafr That’s great! Can you give us some info as to what was happening. It may help some users who experience the same thing.
Which service provider?
What did they say was happening?
I’m with Public Mobile (Telus owned prepaid service).
Found out be reading their forum that some devices need to have some APN settings changed or else bugs can occur.
Made the changes in APN settings and now everything’s good ! :smile:
