No voicemail notification with 1.6.0 on U.S. Mobile WARP (Verizon)
I tested voicemails and get no notification, nor an entry in the call log. :cry: I haven’t had problems getting voicemail notifications with this carrier on other devices, so it should be possible. Is there anything I can check in the config?
That’s odd. I don’t think there are any special settings for voicemail. In this case, we would recommend that you reach out to our customer service for specific technical support. They will probably need to request your logs to see what happened behind the scenes that your VM settings are not working. They can be reached via email at [email protected] or, alternatively, you can submit a support request/support ticket directly on our website:
In the meantime, I would love to hear from other Version customers for feedback on how it’s working (or isn’t working) for you.
