Based on another user on here saying he was using it on Rogers I just ordered the Pure from the outlet. I am going to see if it works decently here on the network, if not I will return it as the outlet also has a 14 day return policy. Hopefully I can have a decent experience with it, as I owned the phone previously and did enjoy it quite a bit
Even your operator has decent reception outdoors, on sub levels and general lower reception areas you WILL loose signal. Once you exit RESTART the phone or you will stay of the grid. Ask operator to enable VOLTE then turn it on on Pure. mp3 player is awful, calendar and notes useless, meditation I dont use. I tested Bluetooth connectivity and it worked with PC, speakers and headphones. But with PC it cannot open even plain text file.
|No T9, messages I used to write from Mudita Center.
So sad all this aspects could be improved in sotfare but phone was EOL after two years. They say new features, I say old ones dont work on Nokia S30 level from 1995.
Design is OK, screen needs more PPI and has only small; fonts, battery longelivity is OK, size is right, two SIMs work.
I decided NOT to do review of Pure 1 since it would be too negative., I hope for Pure 2 after Kompakt success.,
Maps and Signal were stretch goals on Pure, but now Kompakt will have it - also sad factor.
Its better but harder to make dump phone as smart it can be, then to dumb smartie. At least in my book
This was supposed to be based on extensive questionare all of us did fil;l. Did that show we need a smartie or it was just easier path due to limited sw development?
On Kompakt CEO interview early before it started I met in chat coder that was willing to work on MOS and MOS-K. Has he made contact?
