When listening to a podcast from antennapod the content stops, shortley after the phone display times out. I just hit the on button and resume play and it continues until it times out, It takes maybe a minute or so then I hit play again once I get the the display to appear. I messed with settings and probable screwd something up as this has not been a on going issue. Thanks for any advice, Have a Great Day… Jerry
Do the following:
Settings
System
Developer options
Then click on the magnifying glass at the top and enter “Battery.”
Then click on Battery Manager.
There you will see the restricted apps.
Uncheck the box next to AntennaPod.
Done ![]()
I guess your talking about this on my phone…
when I hit system there is no option for developer options .only language and keyboard, date and time and factory reset.
Step 3: Enable Developer Options on Your Android Device
- Go to Settings on your Android device.
- Scroll down and select About phone.
- Find Build number and tap it seven times to enable Developer Options.
- Go back to Settings and select Developer options.
Thanks. .Will see if it works now.
Thanks Gang… The advice you gave me worked, no more issues…
