Network Setting Question
Thank you very much. I will try this. What is the full name of the app?
Here you go!
@harley By chance, do you have any sideloaded apps?
I am having the same issue of not being able to send images.
I am on T-Mobile. I tried making a new APN, but it did not seem to work for me (perhaps I entered something incorrectly?). I have sideloaded apps if that helps.
Does anyone have a solution?
Do you have your MMS function enabled?
To be quite honest, I just factory reset my phone and set everything else back up again and it works now lol. I believe I tested out that setting and it didn’t work but can’t say for sure.
@domonation I’m glad that it worked out. Just out of curiosity- Did you have any sideloaded apps installed?
I had messed around previously with setting other apps as the default SMS app using WebADB. I am pretty confident that this caused the issue, although I was hoping for a way to resolve it.
@domonation Sideloading apps could be tricky because you can never be sure if they will play well with other apps on the phone. With so many apps out there, it’s difficult to predict which ones will (or won’t) have an impact on the system.
