@parawizard: I believe that @urszula will advise you to email [email protected] for help. They may ask to see some sort of log from your Kompakt.
Indeed reading through this list, I am not at all disappointed that I havenât got the update pushed to my Kompakt yet.. I will probably elect to pass this version by and not install it.
Many of the features appear to be in response to incessant complaints on this forum. The only thing I would like to see Mudita add is method to view and close open apps.
Once again, none of the long-standing bugs have been fixed, such as the sound issue when Offline+ mode is enabled, or the problem where an empty SD card is suddenly displayed. And it seems the music player still canât play albums in the correct track order. Itâs very disappointing once again.
Iâm having this issue too. Curious how to fix it @urszula
yes, i have this too since the update to 1.6. iâm not able to clear it in any way. I hope thereâs a quick solution!
@kirkmahoneyphd Thatâs hard to guarantee, you might have to update.
It is good to see an incremental update.
I hope future updates are more frequent.
Let me clarify this, because I donât want new users to misunderstand anything. While our team is doing their best to make sure phones are updated, itâs not guaranteed that you will get an updated phone. Chances exist that you will get a phone which will need to be updated.
Me too with the 9+ calls badge above the Phone tile. Canât clear.
A pinnable To Do function in Notes is a gamechanger for me. Thankyou!![]()
âYet Another Call Blockerâ doesnât work with SMS at all, plus itâs one of these apps that never get updated.
Iâve been using the F-Droid Spam Blocker, and the latest versions worked somewhat well, but strangely it labels contacts as ânon-contactsâ, while still letting them through, so this app also still needs some work.
Our team definitely did great job! I will pass it on to the team.
@urszula any idea how long until all devices are eligible for the ota update? Still waiting (most patiently
If any of you are having trouble changing keyboards, for example because the âKeyboard Settingsâ button bypasses the mudita keyboard settings, instead taking you right into the sideloaded keyboard settings, then you could try searching for âkeyboardâ in the developer options. I managed to change to the native keyboard by first clicking â+ installed keyboardsâ in DevOps and fiddling around inside the menu I was taken to.
Nice update!
Now the Maps app mainly needs the option to set a starting position other than current position in order to be practically usable. This is the sole reason why I donât use that app at all; it shouldnât really be surprising how often it is necessary to choose a starting point.
Whatâs the main use case for setting a different starting location than where you are? Trip planning?
Yesterday, the maps would not update my current location. Quitting the application didnât seem to refresh. I was not able to manually tell it my origin as a failover.
And also yes, trip planning is indeed a core function of a modern map/nav application
edit: My issue is on 1.5, not relevant to this thread.
Does it inclide Romanian? ![]()
I hope thatâll get fixed.
Real digital minimalists use paper maps for trip planning. ![]()
I totally agree. They also use a REAL dumbphone which has a working spam blocker
No Android-based phone can ever be âmindfulâ, because itâs a constant hassle.
