MuditaOS K 1.6.1 bugfix rollout has started
Hi everyone!
We’ve started rolling out MuditaOS K 1.6.1, the hotfix addressing the SIM PIN prompts and persistent missed-call notifications reported after the 1.6.0 update.
Thank you for your patience while we worked on these fixes, and to everyone who shared reports and helped our team investigate.
What’s fixed?
  • Persistent missed-call badges: The Phone app no longer mistakenly counts past calls as missed, and the badge now clears correctly after you view all missed calls.
  • Conflicting missed-call counts: The lock screen and home screen now display consistent, accurate missed-call counts.
  • Repeated SIM PIN prompts after using Offline+: You no longer need to enter your SIM PIN every time you turn Offline+ off. The PIN is now only required when disabling Offline+ immediately after restarting your Kompakt.
The rollout is underway, so the update may not appear on every device at the same time. It is being rolled out in batches. If it isn’t available on your Mudita Kompakt yet, thank you for bearing with us as the rollout progresses.
Once you’ve installed 1.6.1, please let us know how it’s working for you. If you’re still experiencing either issue, share your experience here or contact [email protected], so our team can follow up.
Yippiejaja yippie yippie yeah!
So this not the fall update correct with google calendar sync etc?
This is the one with the VM & all the info on the 1.6 changelog:
MuditaOS K 2.0 is the one with the calendar sync- that’s coming in November
So happy phone will not vibrate anymore for text notifications! Or anything else for that matter lol
Thanks Urszula and team, I just got my update pushed here in Sydney (AU) and installed it. I’m glad the Offline+ issue is addressed with this. Also, I did have the call badges issue but I did the workaround suggested here on the forum and it worked and never came back. Thanks again Mudita!
Fix received, applied, working, thanks ! :slight_smile:
Within what timeframe can I expect to receive the update? Should I expect to get it today, could it take a few days, or even longer? Thanks!
Glad to hear it. Just out of curiosity, which network provider are you using down under? Any issues?
My device does not have a SIM in it, as I am still experimenting.
When might I receive the update? Is there a way to force update?
The updated is rolled out in batches, so there is no way to force it. As far as the SIM goes, the update uses data transfer, so no SIM is needed if you are connected to WiFi. Are you connected to WiFi?
I am on Wi-Fi.
You should be all good.
I haven’t seen it… how is it being rolled out? I’m in Canada, not sure if that helps understand when it’ll hit my Kompakt.
Same here, thanks!
In Canada as well still waiting on mine
UK here, I’m still waiting for 1.6 itself let alone 1.6.1 :frowning: . (Unless 1.6.1 is coming out instead?)
Yes, rollout for 1.6.0 was paused due to several bugs. So 1.6.1 will be available for everyone, even when you’re still on 1.5.0.
I asked a question about the time line for the rollout here, but received no answer. I guess they’re not saying anything about it?
edit: I just received the update!
I’ve had the phone for a month. It’s stuck on version 1.5.0 and won’t find the update. I am in Finland.
The rollout is continuing to move forward, we just released another batch this morning.
Just to make sure we’re all on the same page, the Mudita Kompakt users who previously updated to 1.6- all those users should now be able to download 1.6.1.
Just head to SETTINGS>>>>Software Update to check. Hit the refresh button.
If you are still on 1.6 and have not received the 1.6.1 bugfix, please reach out to our tech support to let us know. Their email is [email protected]
If you’re on 1.5 (meaning you never got the update previously) please be patient. The rollout is happening.
