Pure was working fine, had not installed updates to Pure for a while.
Connected for updates thru the app, which did two consecutive updates to the Pure version on the Phone.
When you try to place a call, I can have three or four bars for signal strength, as soon as you do the call button, the display says “Call ended” and the signal bars go to no connection.
After the updates the phone no longer sends or receives calls. Texts are the only thing still working. I have two Pure phones that now have this problem.
Hoping I can get some support on this problem rather than replace two phones.
@r_g Thank you for letting us know about this problem. Have you contacted our customer support about this yet? I recall hearing about an issue similar to this & it was fixed. Also, have you tried turning the phone OFF & then ON. Sometimes (it happens to my Pure as well) the connection is lost for some reason & the reset is needed to re-establish the connection.
Thanks for the suggestions.
I tried turning the phone off then back on after a few minutes, and even pulled the battery then reinstalled and booted up the phone; no change, still not working.
I have put in a ticket with Customer Support, so hopeful they can find a fix.
