Hello all,
I have not used my Kompakt much since receiving it in June. When I got it I used the included sim tool and popped open the tray, inserted a micro sd card, and closed the tray. Just today I wanted to take the sd card out because I think I am going to give the phone to a friend. I used the included tool and no matter how hard I try the tray wont budge but maybe a few mm. I am not sure what to do because it is far out of the free return window and I really would like for me or my friend to get use out of the phone.
Is the SD card being recognized by the phone? I’m asking this in case it’s not it might have been jammed and is crooked inside.
Could it be you’re using a different sim tool? Because I have one that looks 99% the same, but the Mudita one is longer by a few mm. And one time when I wasn’t home I had to change sims and all I had was a standard SIM tool which wasn’t long enough to reach it. It would come out a little bit but not all way to be able to grab it.
I had to use the reverse side of medium sized needle to be able to eject it.
Did you ever get this resolved? I have the same issue. Opened the sim tray for the first time since getting the Kompakt to put a memory card in which works fine, but now can’t open the sim tray again. Using the sim tool that came with the phone.
I had this same experience. For some reason Mudita made the SIM card slot require a longer SIM tool than the average one. This would be a future model request to make sure that the SIM card slot is the average length.
I have also found that the gasket used on the SIM card tray is much stronger than other phones. Even if I use the tool, it only ejects a tiny bit. I then have to pry it out with my fingernail. It may be that it’s just very sticky… It almost feels like I’m going to break it sometimes trying to dig it out. To me, this is a design issue that needs to be fixed with future Kompakts.
Same with mine, I don’t plan to swap sims often.
I talked to our team & they suggested that If the included tool isn’t working, try a thicker pin (like an earring prong or the reverse side of a medium-sized needle) because a thicker tool can hit the ejection point more reliably. I used my earring once & it worked like a charm.
If that does not work for you, please let us know.
No matter how hard I try, no matter how hard I look, I just can’t find my earrings…
@YYZ I see what you did there… ![]()
The tray in the Kompakt is amazing how it accommodates sim cards or a sd card and sim. That.s genius!
I had the same issue. Leaving a comment in case someone else has this issue. Found the fix in a YouTube short. Insert sim tray tool and hold in place with a finger, flip phone over, gently tap on a surface until it ejects. Took a few tries but it got open. It took a moment to wiggle out but it’s free!
I’ve found the tip of a mechanical pencil to be a fantastic tool for the job
