Hi,
I’ve been using MK as my primary device for a couple weeks now and I just want to say how much more I appreciate all the small things that happen around me compared to when I used my smartphone as my only device. I still feel the need/cravings to get hold of my smartphone (it’s turned off and in a cubbard at home and only used for checking my banking apps, amazon…) and check apps I don’t have on my MK.
The overall experience has been quite challenging, coming from a sysadmin used to mature systems and quite demanding as a user when it comes to technology, but very gratifying. Getting used to not having a smartphone in our pockets is harder than expected.
The E-ink UX is amazing tbh, I didn’t expect to like it so much, the screen response is much faster than expected. Calls are clear, battery life is insane (I come from an apple device). I could go on for a while on the pros.
I would like to make a few suggestions/point out a couple of things I would like:
-In the sound menu, I think that the ring and notification volume should be two different options, not the same one, like it is atm. For example, If I needed to have a high volume on the call option to obviously not miss calls but less volume on the notification option so whenever I get a notification, the whole room doesn’t look in my direction, this would solve this problem. Sometimes I can’t put it on silent mode because i’m expecting a phonecall.
-If I call someone and I’m using cabled headphones, they can’t hear me, somethings going on with the mic. Same mic works perfectly on the recorder app and on other devices.
-I just updated to MuditaOS K 1.6.1 and the estimated battery is “about 1 day” being fully charged. Could it be it’s recalibrating after the update? Does the new version have a different battery consumption?
-It would be nice that the music widget displayed what song it’s playing rather than just the control buttons.
If I’m doing something wrong that would solve any of these problems/requests, please let me know.
Also thanks to @gezimos for all the hard work. Katapult just upgrades the whole UX. I feel like some of the things you use on katapult should just be implemented into the native OS.
I love and believe in the direction mudita is going towards with it’s device.
Thanks a lot.
