Mic Drop Out, USB Hotspotting and Missing Features
Hi there,
I have had my phone now for just shy of a year. Having got rid of my smartphone in August, it has been my only device and it’s generally been fantastic. Having previously used the Hisense A5 and having to do a lot of stuff to get it to feel like a great e-reader dumbphone with whatsapp, it’s been great going to a device like this that has been built from the ground up with this idea rather than trying to hack a device to work the way I want it to.
Thank you for making such a great device!
I wanted to ask about two issues I’ve been facing, just to see if others have as well and if there are solutions.
  1. Has anyone been mid/early-call and then had their microphone drop out? It’s happened to me three times. I have found that putting it on speakerphone seems to stop it from happening, so perhaps it’s been connected to going to sleep. Frustratingly, the calls have all been about jobs so it’s definitely the biggest issue (“Are you still there”). Not seen it on the new update yet, but I also have just got into the habit of putting it on speakerphone.
  2. Has anyone got USB tethering to work? It just says there’s no network on mine. I’ve tried it with USB C to USB A and USB C to USB C. Both haven’t worked. Would love to get it to, as plugging in is my preference. If I wanted to get ethernet hostpotting to work, what would I need to do?
  3. Most importantly, is a two-player mode coming to chess? Or being able to turn the pages with the volume up/down button? Come on, these are critical features Mudita :enraged_face:.
Thank you! :blush:
Different cable? - a usb data cable, that may help.
The Kompakt hotspot WiFi is very good, in my experience
Microphone? You might be holding your finger over it?
I think the microphone is on the bottom of the phone.
Does wired hotspot work for you? I have tried about four different ones and they all haven’t worked, so I would be apprehensive to buy another one.
The microphone straight up dies during the call, like the hardware has been turned off. And even if I move it to speakerphone and hold it in a different way it stays off until I call them again.
I haven’t used a wired hot spot with the mudita phone
Contact support the mic problem CUSTOMER SUPPORT:
SUBMIT A TICKET
@scottsaw welcome to the Mudita Forum. We’re glad you’re here.
Thank you for reaching out.
I have not, yet, heard of the microphone giving out. Whenever someone mentioned a dropped call, it was usually a network issue.
I use USB tethering quite a lot & never had an issue. Just to make sure we cover all bases, are you turning it on in the settings?
Two-player mode has been discussed, but no decision was made. I will follow up with the team.
