Hey everyone,
I’ve been enjoying the custom apps other Kompakt users have made (Calm-Apps, Launchers, etc.), so I figured I’d take a crack at the thing that’s been bugging me the most: the calendar. I love the design of the original calendar app, but having no sync really annoys me. Third-party ones like Etar just look awful on E-Ink in my opinion.
Anyways: I tried to clone the native Kompakt calendar app as closely as possible and extended it’s functionality with DAVx5 support
You can download the apk from the releases section and DAVx5 from F-Droid ( DAVx⁵ | F-Droid – Freies und quelloffenes Android-App-Repository ).
KompaktCalendar on Codeberg
Looking forward to hearing your feedback
FYI: I haven’t been able to 100% confirm that notifications always work (and the app is not killed by battery optimization)
Sounds promising, looking forward to give it a try (currently using Fossify Calendar with DavX5 but I really like the native calendar simplicity. Unfortunately it doesn’t with the native Android calendar which is a missed oppurtunity as contacts do, through CardDav.
Thank you! Can’t wait to try this.
Does it support American time (AM/PM) and date (MM/DD/YYYY) format as well? Is it possible to get event notifications the day before the event at a specific time?
Hey, it supports 24-hour format and (am/pm) and automatically takes the one you set in android settings. Dates are always written out (e.g. 26 April) so there is no real date formatting anywhere. For event reminders there are currently a couple of options (5 min, 15 min, 1 hour, 1 day, 1 week), but there is no way to set the exact reminder time/date at the moment.
Actual audible notifications are still in the works right now, but seem to be working well in my development version. Still need some time though to see if and how the battery optimization kills it
@david-ger: Does KompaktCalendar support recurring events?
Wow, you guys really make this phone from being an okayish experience to a perfect E-Ink-use-your-phone-less solution. Its really a joy to have all these tool-apps (meaning not capital interested apps with a lot of commercials or addiction factors) on it!!
And again, how about adding it to Mind Apps?
Thank you! It seems really cool! I’ll give it a try.
good call, can’t believe I haven’t thought of that. the current release doesn’t have it yet, but I’ve been working on implementing it and the next one 100% will.
I’ll let you know here, when it’s out
Ahh, that’s what it was called. I knew there was a store-like app collecting all the Kompakt-optimized apps, but I couldn’t remember the name.
Anyways, submission sent. Thanks for the suggestion
hi @david-ger does it also work with outlook?
just tried it, unfortunately outlook app didn’t work.
Loving the app. Thank you so much! A few suggestions:
- Can we have an American date format as an option (“Sunday, May 1”)
- In the agenda view, the date of the event is hard to distinguish from other events and other dates. Can we have the dates underlined or bigger perhaps than the event and time? Or have the font weight be stronger?
- Can we have multiple reminders for one event?
- Can we have a snooze option for events in the fullscreen notification?
Thank you again! I didn’t use the stock calendar because it’s so barebones, but this one is perfect, especially since it syncs with my iCloud calendar.
Thank you so much for this, it’s fantastic and has made moving to the Kompakt full time much more realistic for me. One thing I noticed is that all day events from my google calendar are appearing in the All day section for the day after too- e.g my ‘Bank Holiday’ reminder for yesterday is still visible in the All-day section today. I’m wondering if its something like the Google all day event is being treated as midnight to midnight and therefore spanning across two days?
Thanks again for this brilliant app!
Very cool. Could be on Mind Apps?
Looks like I will be testing this one out. As an Outlook slave (via work) I need to be able to import from an ICS link to se my work schedule. Will ICSx5 work as well as DAVx5?
Hello guys, thanks for all the suggestions! I tried adding as many as I could:
Version 1.1.0
New Features
- Repeating events — set events to repeat on a schedule
- Multiple reminders — add more than one reminder per event
- Custom reminders — choose your own reminder timing
- Snooze — snooze reminders when you need a few more minutes
- Location option — attach a location to your events
- DuraSpeed toggle — Quick disable DuraSpeed battery optimization from the settings
Fixes
- Design brought closer to MMD guidelines
- Fixed all-day events appearing on the day after
- Many more under-the-hood fixes and improvements
Download here
ICSx5 seems to be using the android calendar system too, so it should work. Let me know If you tried it.
Great updates! Thank you. So much better visually as well.
This is perfect, thank you! Beautiful and simple, exactly what I wanted for my phone.
I could overlook a lot of the minor issues with the phone because I love it so much, but it was really difficult for me to not have my medication reminders and I hadn’t been able to come up with a reasonable solution. I’ve now set a daily event on KompaktCalender - problem solved!
This is perfect! I immediately switched to this app on my HiBreak Pro.
I am praying for someone in the community to make an eink optimized app for a task list! That would be ideal
