Amazing, a great update thank you
Have now got a chance to try it out. So far it works perfect. Still need to use it for a few more days to get a feel for the everyday scenarios I will encounter, but ICSx5 works and gives me read acces to my Outlook calender. Thank you somuch!
Cheers
Carsten
@david-ger: Great app!
Might you be able to add a setting to allow users to choose to have it open to the Agenda view instead of only to the view of the current month?
I became accustomed to the Etar app opening to the agenda, so I miss this option on your app.
Hello, what’s the default “PC sync” when you don’t have any calendars synced? Thank you for this great app!
Fogive me double-posting; just wanted to make sure I ask in the right place (happy to delete the other post.
Hello!
I’m considering using a Mailfence account + DAVx⁵ as my main contacts and calendar backend, and I’m trying to understand how this would interact with Mudita Kompakt and Mudita Center.
Given that my understanding is that it is currently possible to sync contacts via Davx5 with the native contacts app, and calendar with Etar or similar, here’s the workflow I’m aiming for:
Mailfence serves as the central contacts and calendar hub (via CardDAV/CalDAV).
On Kompakt, DAVx⁵ syncs Mailfence contacts and calendars with the native Contacts and a third-party Calendar app.
On Mudita Kompakt, I would manage contacts directly on the phone and via Mudita Center on the desktop.
My question:
If I set up Mailfence + DAVx⁵ on Mudita Kompakt contacts and calendar, and then add or edit contacts on Mudita Kompakt or in Mudita Center, is there any way for those changes on Kompakt/Mudita Center to sync back to Mailfence (via active CardDAV/CalDAV sync), or is the current Mudita ecosystem strictly one‑way import without true two-way DAV‑based synchronization? If it’s one‑way only, are there any planned features or workarounds to support full CardDAV/CalDAV sync for contacts and calendars?
Thank you!
Please go here for my response! Thanks!
