KashCal review by paxristi
KashCal β€” Community App Review
Version: 23.7.53
Stable calendar with built-in DavX-sync support and ability to directly sync with iCloud, Nextcloud, etc. Can also directly add new ICS subscriptions (and disable them from syncing).
Not optimized for eInk screens, but the various views look great to me. Before using KashCal, I had been using Etar and Fossify. KashCal is by far the superior calendar app and is being actively supported and updated.
Review for version 23.7.53
User rating: β˜…β˜…β˜…β˜…β˜†
I too reccomend it. Would give 5 stars if specifically designed for E-ink. Great regardless.
Author’s rating: β˜…β˜…β˜…β˜…β˜… Β· Author of this review
See related topic here: Calendar Sync. Icloud Solved!
User rating: β˜…β˜…β˜…β˜…β˜…
Been using KashCal for a few weeks now, highly recommend for sharing iCloud calendars with family. I have my entire life in iCloud calendar (probably a mistake) but this has made my switch to MK so much easier.
Since I started this review, I must admit that I have now switched exclusively to using Homie (https://forum.mudita.com/t/homie-family-organizer-review-by-oyvind/). I highly recommend you trying it out if you don’t want or need DAVx5 syncing!
