Hi everyone. I love the meditation app but the chime sound it’s just too annoying. It gets you off the meditation state when you hear it. I wish there was an option to just use this sound at the end so I know that is finished. If I choose 15 minutes and every 5 minutes the chime I need to keep count how many times it plays. Maybe a different sound at the end to know that the meditation is finished? And maybe a relaxing sound instead the chime sound ?
Hi Shak! If it’s Pure you’re referring to there is an option to change the chime to NEVER by scrolling left or right to select it. It’s so great that you’re using the app!
Hi . Yes i am aware of that option. The problem is that this way i dont be able to know when the meditation session is finished.
Yep, I found that too…
This improvement suggestion listed on this thread… PURE - Meditation Timer Suggestions
