I wanted to ask if it is possible to implement the select network function manually, since I live on the border To Italy and Swiss?
Unfortunately it happens that it connects to the wrong network in Romning to Italy and not to default provider in Swiss
Tks
or at least the option to disable roaming, also we need an option to show battery percentage without the need to connect to PC
@dcalliari Thanks for reaching out. You’re not the first one to bring up the desire to have this feature. I have passed it on to the team.
the ability to select the network manually exists in any phone except on the mudita. why is it not implemented in this phone, if you can call it?
I think this feature would be very helpful.
