I hit ABOUT… Then BUILD NUMBER 7 Times… Then go back to settings and No DEVELOPER option appear… I turned off phone, then refresh phone, this was done8 times and nothing… What do I do… Im not a teenager or a IT guy, so please be patient. Thx
You can just go to settings → system → developer options if you are on OS 1.4.0.
After you navigate to Settings > About and tap repeatedly on Build Number until a message pops up and confirms that you have enabled developer mode, you will then find the newly unlocked developer options by navigating to Settings > System > Developer Options.
Your way worked while no one else did…Thx
Now im trying to get notification when a new podcast has hit. I use to have a dot under inbox now I have to refresh
every morning to see them… Using antenna pod
