I’m trying to figure out of the phone has GPS capability because I would like to have a phone without it. I’ve checked the forum and FAQs and can’t see a clear answer so please can someone confirm?
Apologies if I’ve missed it somwhere! Thank you
It won’t. There is no internet on the phone, but it can be used as a modem.
@georgethefrog In order for the GPS to work (i.e. to be able to read the position of the phone from the module), it is necessary to add an antenna track and a GPS antenna. Mudita Pure does not have GPS because it does not have a functional GPS module. Hopefully this helps.
you can check code pro zone the internet or you can use antennae or tracker
