@zeppelin87
Thank you for coming back with more feedback. I will do my best to address all your points individually. This way, I can make sure to tackle all your concerns.
Hangs frequently, sometimes 2-3 times a day, when it is locked. No notification or anything, you just see that the time is frozen and the right button triggers a restart. Sometimes I don’t discover this for a couple of hours and therefore miss calls. Our team is currently working on all the bug fixes that are coming up in MuditaOS. The next update, which is planned for next month, should fix many of the stability issues people are having.
Long SMS-es are actually being cut-off as others have stated, but not in all cases. Not sure what triggers this. This issue is being addressed.
Hanged at least once by an incoming call, and could only be rebooted by removing the battery. Showed the missed call after the hard reboot. I am reporting this issue to the devs.
Happened once that I got SMS that I have missed calls, but the phone did not display the call in the list or on the lock screen, only the SMS from the operator. Also not sure if I heard it ring at all, so it might have “missed” that? This could be caused by a network/carrier issue. I will ask the devs about this. I’ve also noticed this on other phones. If I get a phone call while I’m in a dead spot, like my underground garage or an elevator, the missed call notice will not appear, just an SMS from the carrier.
If NW power is low, the phone switches to other network type, this switch is slow and show no connectivity for some time, before being OK. We’ve noticed that switching between networks in not instantaneous & can take a minute or so to register. I will ask our team if there’s anything that can be done about this or perhaps this depends on the network.
Music player only sorts files in ABC-order of the song - artist, album or filename based sorting is not available (for FLAC, even though it has tags and they are shown). The music player is being revamped. An improved version will be available in a future update.
When copying over files to the internal storage on Linux, I can not copy folders, only files. It allows me to drag the folders over, but when the copy is done, the folder is gone and the files are scattered out in the root folder of the memory. Is this by design? This is not by design. Like I mentioned in the previous point, the music player is being reworked. The goal is for user to be able to upload audio files to their device via Mudita Center. Currently our team is working on implementing this feature & it should be available in a future update.
The previously mentioned issue on Mudita Center being able to resolve the hungarian charachters (à ő ű ú ó é á ö etc.), but the phone shows squares in SMS and in contact list for most of those. Thank you for bringing this up. The Polish language also has special characters, and those appear fine. It should not be an issue to impellent them for other Latin alphabet languages.
If you’re having trouble submitting your logs to Mudita via Mudita Center, there is a thread on the forum with instructions. The link is here: How to send logs to Mudita via Mudita Center
