Does anyone can refer me to a building biologist or EMF radiation specialist who can carry out an EMF survey in Poland? I have a friend expat who have problems while sleeping and I’m sure it’s due to electrosmog. Thanks.
@cemprotecta Thank you so much for reaching out. I will ask our team members if we can provide such a recommendation.
Thanks a lot!
Hey there! Sorry to hear about your friend’s sleep problems. It’s worth looking into electrosmog as a cause. I’m not able to recommend someone who does EMF surveys in Poland because I don’t have recent information, but you can try searching online or asking local organizations for help. In the meantime, you can try using EMF fabric to reduce your friend’s exposure to EMF radiation. This type of fabric can be used for clothing to help block or shield EMF radiation. Good luck finding a specialist and reducing your friend’s exposure to electrosmog.
Hi Adalyn and thanks for your reply. Yes, of course, that’s why she needs a specialist who knows what to look for and quantify exposure levels. If anyone can share contact information of any EMF or EHS association, I would really appreciate it. Yes, EMF shielding materials could help, but as a building biologist myself I wouldn’t recommend them without knowing what you’re being expose to. EMF shielding materials in close proximity to the body (less than 10 cm.) are a double-edged sword. Thanks for your help.
