Hi,
I got my Mudita Kompakt earlier and set everything up with the help of the community. The problem i faced was adding my second Sim as a E-Sim. I got in touch with my carrier and they tried to help me in every way. To add an E-Sim they said, they need the IMEI Number and the EID of the device.
So i searched the device and the IMEI numbers were easy to find: in the settings; With a hashcode, on the back of the device or on the packaging.
But the Problem is the EID of the device. They said they cant turn on the E-Sim without this and therefore i tried to look it up but couldnt fint it. On every other device i owned it would be seeable in the settings or on the other options, but on Mudita Kompakt it is like it doesnt exist.
I saw that other people also have issues with their E-Sim Actiovations and i think if we can see this number, a lof of these issues would be easy to fix.
I also can’t find the EID number, and GCI, my carrier, requires it for e-SIM activation as well. Any help would be much appreciated!
I found this post by using the magnifying glass at the top of the Mudita Forum to search for “EID”.
