Is there a way to disable the lock screen? Maybe I am doing something wrong, but the phone does not ring when the lock screen is on.
@bill Thanks for reaching out. I’m sorry that you’re experiencing issues. Are trying to remove the option of inputting a passcode every time you want to use the phone? Or are you referring to the need to press “UNLOCK” followed by the # key in order to use the phone?
