Cannot receive calls or texts on Mudita Kompakt
Hi!
Since starting out my Mudita Kompakt journey about a year back, I have experiences problems with calls. Living in Denmark every time I crossed the bridge to Sweden (something I do frequently) I lost the ability to make or receive calls on my phone. Internet connect was still there, but could not call. Phone worked fine upon returning to Denmark.
I switched phone company about a month hoping this would resolve the issue. Instead, it made i worse. Now I frequently miss out on receiving texts and many (though not all) cannot call me. Instead they get the message that “the number is not longer in use” or similar.
My conclusion was that this must be a mobile network provider issue. I have called them several times (provider is ‘3’). When they run the numbers I give them, they tell me the problem is with the provider and not with them. They also say they cannot provide any assistance with settings because Mudita is not a supported phone. I have checked the info for other phones but cannot find any error. The settings data seem to check out.
What can I do to resolve the issue? It is starting to become so serious I have to consider leaving the Mudita Kompakt family.
Please help!
Regards
Jonas
Have you compared the cellular bands that your Kompakt supports with the cellular bands supported by your cellular carrier in Denmark AND in Sweden?
@jonas155 I remember troubleshooting the issue with your last year. It was definitely an unusual situation.
In this case, we would recommend that you reach out to our customer service for specific technical support. They will probably need to request your logs to see what happened behind the scenes for this to occur. They can be reached via email at [email protected] or, alternatively, you can submit a support request/support ticket directly on our website:
They will most likely request logs, to see what is happening behind the scenes.
Hi @kirkmahoneyphd!
No, I have not. How would I go about doing that if I may ask?
Regards
Jonas
@jonas155,
Per https://store.mudita.com/store/mudita-kompakt-global, your presumably GLOBAL Kompakt supports these bands:
  • 2G bands: GSM 850 / 900 / 1800
  • 3G bands: UMTS B1 / B5 / B8
  • 4G LTE - FDD: B1 / B3 / B5 / B7 / B8 / B12 / B13 / B18 / B19 / B20 / B26
  • 4G LTE - TDD: B34 / B38 / B39 / B40 / B41
Compare those to what your carrier supports in Denmark and to what your carrier (or your carrier’s international-roaming partner) supports in Sweden.
