Camera is not functioning.
The screen of the camera stays white in the Mudita Camera app:
nothing happens.
The camera also doesn’t work anymore in any other apps.
I tried:
restart the phone
shutdown + start the phone again
Any idea?
What should i do now? factory reset?
It’s a bug related to Offline Switch (introduced in v1.2.0), not fixed in 1.3.0.
Here’s how to fix it:
Waw, thank you for you quick response.
I toggled it off and on again, and it works again now.
This forum and the contributors are really a game changer! love it.
Mine hasn’t been working for a couple weeks either. I’ll try the fix below, thanks for posting!
It worked, thank goodness!
I’ve had this problem a couple times too. So far I’ve found that switching Offline+ on and then off fixes it immediately.
And that it doesn’t happen again, don’t toggle online/offline on a locked phone.
urszula
October 30, 2025, 11:11am
8
@T9Pilot Our team is aware of this & they are working on getting it fixed. We’re sorry for the inconvenience, but the workarounds/ fixes presented by the community seem to do the trick. However, it will be fixed in a future update.
tobi
November 4, 2025, 10:15pm
9
Glad to hear this! It is a really annoying bug and I missed a few great shots because my camera app was not up to the task. The community fix simply does not work fast enough.
shadock
November 5, 2025, 12:37pm
10
It would be nice, before posting a new subject for things like that, to do first a quick research.
This subject has been treated over and over.
T9Pilot
November 5, 2025, 3:04pm
11
sure, my bad, but it’s such a surprise that voicing it isn’t that crazy to be honest, VS a thread deep burred that everybody has to find?
Also this particular post helped another user that was struggling for a couple of weeks… so it gave visibility to the fix.
There is an easier way to make it work again. Open the camera app, blank screen appears. Now enable offline+ and then disable it. Camera is alive.
shadock
November 5, 2025, 7:30pm
13
Yes, but don’t toggle Offline+/online on a locked phone and you won’t have the problem.
