Bluetooth issues
Hey all! Loving my Mudita Kompakt so far.
I’ve encountered a rather glaring issue whilst using this phone. I can’t quite understand why I can’t see a list of all the Bluetooth devices my phone is connected to, like you can on a standard phone. I usually just have to hope that whatever device I want connected, connects on its own. I seemingly do no have any choice on the Mudita end to attempt to connect to a device, as I do not have a list of devices to choose from. All the Bluetooth screen allows me to do is connect to new devices, not existing ones. Is this an issue anyone else is facing?
Yes. I have the same issue. No list of connected devices.
Hi- I’m sorry that you are experiencing issues. We do have some bugs with Bluetooth and they are currently being ironed out. They should be fixed a future update.
Thanks for the response! I assume it will be an easy fix, so I am not too worried.
The bluetooth on my mudita does not work at all. If I try to turn my bluetooth on, it will turn on and off by itself for at least 2 weeks. This makes my battery barely last a day, which is the part I am most frustrated about. I hope I can get some help with this soon or I am going to have to give up on this device.
Let me see if I understand this correctly. It randomly turns on & off? Or it doesn’t turn on when you need it to?
Whenever i touch the bluetooth icon, it flashes on and off for at least 2 weeks. This makes the bluetooth unusable.
I figured the problem out, I had to toggle with the bluetooth settings and turned off the “Gabeldoarse”? settings
@lliomoyers Yes, our devs said that by default this setting is OFF.
