It happened to me as well. I tried clearing the bluetooth history using adb, cleaned the cache, restarted the bluetooth service and nothing worked.
How I was able to reconnect them is installing the Companion app for my Earphones, in my case it was Nothing X (for Nothing Ear earphones). And I was able to recconect them.
So if you have a brand of earphones that have a compaion app to manage the earphones, try connecting through there until Mudita provides an update.
Same problem here. I also have a problem where the music or podcast pauzes after 45 seconds when i play it on a sideloaded app (not when i use the music player, but that one is a nightmare to use).
Found workaround for bluetooth dissapearing: Bluetooth Audio Connect Widget sideloaded by Aurora store
In this app you can see the list of paired devices and manage them
A very promising solution! Hopefully a permanent one too.
It actually worked on the first attempt. For my personal use cases, this would eliminate the last reason to carry a smartphone in certain situations.
Thank you very much @chrisoakee !
I had previously connected to my Bluetooth speaker and went to connect today and it would not. So I came to the form looking for an answer and it looks like the Bluetooth audio connect Widget has worked for others. I tried to download Bluetooth audio connect widget and it is giving me an error saying it could not get the files. Anybody have experience with this or run into the same issue?
Iāve updated to 1.2.0 and still have this problem. Devices I connected with in the past canāt reconnect because I donāt see them anywhere, and I canāt pair them again because theyāre already pairedā¦
